Bucharest
Vand:
Tamper Motta 58.5 mm - 50ron
Milk Pitcher Joe Frex 360ml - 50ron
Puly Caff praf backflush 9 x 20gr - 15 ron
Puly descaler - 8 x 30g - 20ron
![[Image: Hhc4cNF.jpg]](https://i.imgur.com/Hhc4cNF.jpg)
![[Image: m394XPS.jpg]](https://i.imgur.com/m394XPS.jpg)
![[Image: cUYc5lP.jpg]](https://i.imgur.com/cUYc5lP.jpg)
![[Image: KT5PKGM.jpg]](https://i.imgur.com/KT5PKGM.jpg)
![[Image: 4GZEGu3.jpg]](https://i.imgur.com/4GZEGu3.jpg)
Kinu m47 Phoenix | V60 | French Press | Hario Mizudashi 1000ml | Aeropress | Fellow Prismo | Amir 3000g, 0.1g
bucuresti
salut, ma intereseaza tamperul si latiera. iti dau pm.
merci!
#Faema E61 Legend #Olympia Cremina 67 #LaPavonis #LaPeppina # Gaggia Mini #Aeropress #Mythos 1 #Niche Zero #Kinu Classic M47 | ex: #Expobar Brewtus #BFC # Gaggia Classic
Bukarest
Interesat de latieră.
Și de ce părere ai despre Staresso.
Mazzer SJ | Zwänger Favorite Typ0 | Isomac Giada | Promac Lollo | Tecnosystem Blitz | Gaggia Dose
Bucharest
17-05-2021, 19:47
(This post was last modified: 17-05-2021, 20:18 by kamikaza333.)
Milk pitcher and tamper reserved for bogono, to be picked tomorrow.
Neuzeitlich - It's a nice traveling device if you don't wanna carry V60 gear with you and are into stronger coffee preparing methods. On top of that, it's quite forgiving with extraction, as long as you don't grind too fine, this will clog it and won't get any coffee out.
So far almost every shot I had with it was acceptable, but don't expect the same strength per ml as an espresso machine. The ratio is also different in order to extract well enough, about 80ml in, 10-12g coffee, 50-ish ml output. If u lower the amount of water, you most likely won't extract enough to taste well.
Puly backflush and descaler reserved for @
gabrieldima
Bucharest
Milk pitcher - 50 ron
and Tamper - 40ron
were sold to @
bogono.
Bucharest
The Puly backflush and descaler powders are available once again until next week.
If they're not sold untill then, they will be bought by @
gabrieldima.
The reason for the cancellation by his side is that he doesn't have the time to pick them up this week.
