Tamper, Latiera, Detergente - Printable Version +- Forumul Espressoman - In cautarea espresso-ului perfect (https://www.espressoman.ro/forum) +-- Forum: Comunitatea de espressomani (https://www.espressoman.ro/forum/Forum-Comunitatea-de-espressomani) +--- Forum: Marketplace (https://www.espressoman.ro/forum/Forum-Marketplace) +---- Forum: Vanzari espressoare, rasnite si accesorii (utilizate) (https://www.espressoman.ro/forum/Forum-Vanzari-espressoare-rasnite-si-accesorii-utilizate) +---- Thread: Tamper, Latiera, Detergente (/Thread-Tamper-Latiera-Detergente) |
Tamper, Latiera, Detergente - kamikaza333 - 17-05-2021 Vand: Tamper Motta 58.5 mm - 50ron Milk Pitcher Joe Frex 360ml - 50ron Puly Caff praf backflush 9 x 20gr - 15 ron Puly descaler - 8 x 30g - 20ron ![]() ![]() ![]() ![]() ![]()
Tamper, Latiera, Detergente - bogono - 17-05-2021 salut, ma intereseaza tamperul si latiera. iti dau pm. merci! RE: Tamper, Latiera, Detergente - Neuzeitlich - 17-05-2021 Interesat de latieră. Și de ce părere ai despre Staresso. RE: Tamper, Latiera, Detergente - kamikaza333 - 17-05-2021 Milk pitcher and tamper reserved for bogono, to be picked tomorrow. @Neuzeitlich - It's a nice traveling device if you don't wanna carry V60 gear with you and are into stronger coffee preparing methods. On top of that, it's quite forgiving with extraction, as long as you don't grind too fine, this will clog it and won't get any coffee out. So far almost every shot I had with it was acceptable, but don't expect the same strength per ml as an espresso machine. The ratio is also different in order to extract well enough, about 80ml in, 10-12g coffee, 50-ish ml output. If u lower the amount of water, you most likely won't extract enough to taste well. Puly backflush and descaler reserved for @gabrieldima RE: Tamper, Latiera, Detergente - kamikaza333 - 18-05-2021 Milk pitcher - 50 ron and Tamper - 40ron were sold to @bogono. RE: Tamper, Latiera, Detergente - kamikaza333 - 20-05-2021 The Puly backflush and descaler powders are available once again until next week. If they're not sold untill then, they will be bought by @gabrieldima. The reason for the cancellation by his side is that he doesn't have the time to pick them up this week. |
