Mahlkoenig X64 SD
Mahlkoenig X64 SD
Ultimate Versatility in a Single Grinder
Allround grind size scale that fits many brewing methods, from fine espresso to coarse French press and cold brew
Precise results with stepless grind size adjustment on micron level
64 mm special steel burrs, even particles for an incredible taste experience
Single dosing for the ultimate versatility
Zero retention, no coffee grounds left behind, fresh dose every time
Reduced noise, whisper-quiet grinding perfect for early mornings
Fastest grind with a minimum output of 3 g/s for espresso
Smallest footprint, so compact you can literally take it anywhere
Built-in grind size guide inside the lid
Easily swappable hopper attachments for smooth operations
Bellow for those who value convenience and cleanliness
Accessories (included):
Stainless steel portafilter dosing cup with funnel
Easily swappable hopper attachments:
Hopper extension for more capacity
Bellow for easiest purging
Anti-popcorning lid for smooth operations
https://www.mahlkoenig.com/products/x64-...me-grinder
https://youtu.be/ap_c2sThQ5E?si=OT-oQ4dnqLyN4KYF
Too late, too expensive, too...
Nici macar #metoo SD, e doar o aparenta ca ar fi inclinata, cutitele tot orizontale au ramas.
Doar cu un burduf nu faci SD dintr-o rasnita cu cutite plate.
Eu aveam ceva sperante cu asta pentru ca sunt in cautari, si vreau un upgrade.
Pana am citit in MANUALUL ei, la pagina 23:
Quote:Max. permissible operating cycle 6 sec. on / 54 sec. off
Recommended break: 54 sec.
Tradus (pentru convenienta Dvs), mai exact:
Ciclu de funcționare maxim admis 6 sec. pornit / 54 sec. oprit
Pauză recomandată: 54 sec.
Mai bine puneau un motor normal la cap, care sa "indure" mai multe secunde. Sa pui un disclaimer de genul asta, e cam de porc!
Si ma atragea ideea, jur... Mahlkoenig, pun SSP pe ea... etc samd... e mica, o iau in concediu la nevoie...
Lelit PL41TEM, F74 Navigator, Sage Bambino, Niche Zero
Multe rasnite de soi au aceasta atentionare.
Si E65, 5 sec / 30 sec
Mai mult sunt scrise din cauza incalzirii boabelor.
pai macina in 5, 6 secunde 20 grame de boabe la macinatura de espresso? sunt cutite de 64, si mai stau si la orizontala. bine observ ca are aproape 2k de turatii, le face vraiste. Cauta cineva asemea turatii?
Da, deci sa inteleg ca nu crapa in primul an motorul. ideea e ca desi in 5,6 sec macini, realitatea este ca mai dai la blower (sau o palma mica) si te duci lejer in 10 sec; si iarasi, turatiile astea mari fac cumva mai riscanta sau nepotrivita si schimbarea cu SSP-uri...
Eu m-am tot uitat la DF64, si mi-e teama sa nu nimeresc vreo rasnita asamblata aiurea de nu o poti alinia. La Macap-ul meu entry level, cand am facut-o la marker, a iesit tzutz. De 3 ani o am cu cutitele aliniate, inainte 2 ani stock; si parca e alta rasnita, ies aromele din punga 1:1, chiar daca nu sunt extrem de clare si separate, cum probabil o face o rasnita mai buna. La fel, m-am uitat si la Mazzer Philos. Ideea e ca vreau o rasnita de nivel superior, nu vreun entry-level si acest X64 SD nu mi se pare ca e acolo. Poate ma insel, dar, nu as risca. Si imi placea ideea de brand bun, cutite plate si dimensiunile mici...
La nivelul entry Mahlkoenig e doar o iluzie de brand bun, indusa masiv marketingul din spatele liniei de top.
Vario a fost o catastrofa, care o cumpara lumea ca nu avea referinta sa compare.
Iar cele de top aveau un pret din alta galaxie... si cu pretul ala tot existau plangeri ca vin nealiniate.
A fost suficient sa apara noul val de rasnite, ca sa nu mai reprezinte o alternativa atractiva nici acelea.
Ca sa fiu un pic ironic... "pana si Honne" e preferabila unui Mahlkoenig la pret dublu.
Iar modelele de consum, care le scot acum, dupa 10 ani de pauza... creatoare Tongue , arata ca nu inteleg nimic din ce vrea piata.
