Vand Nuova Simonelli Oscar II - Rosu - Printable Version
+---- Forum: Tranzactii incheiate (https://www.espressoman.ro/forum/Forum-Tranzactii-incheiate)
+---- Thread: Vand Nuova Simonelli Oscar II - Rosu (/Thread-Vand-Nuova-Simonelli-Oscar-II-Rosu)
Vand Nuova Simonelli Oscar II - Rosu - dinurm - 16-01-2020
Vand Nuova Simonelli Oscar II - 2600 RON
In cateva cuvinte, un espressor prosumer cu un raport calitate-pret excelent, tehnologie HX, abur puternic si stabilitate termica buna asigurata de boilerul de cupru de 2l. Espressorul este luat din 2016 de la elektros.it, cu revizie facuta anul trecut.
Pachetul contine:
- OPV Kit instalat din fabrica
- Portafiltru original 550g echipat cu sita IMS (spout dublu inlocuit cu unul de metal)
- Portafiltru Naked + sita originala de 1 cafea
- Garnitura Silicon Cafelat  + 3 garnituri originale
- Sita dus - originala + IMS Nano Quartz, adaug si o sita IMS teflon, cam uzata dar in stare de functionare
- Surub dus cap ingropat +cel original
- S-a facut revizia de 2 ani undeva in vara anului trecut, piesele din poza (~250 RON) au fost comandate integral, dar nu am inlocuit pistonul pentru steamer intrucat nu era uzat (un cappucino pe saptamana max). Piesa ramasa + oringul afarent sunt incluse in pachet pentru inlocuirea de catre viitorul posesor cand va fi cazul.
Motivul vanzarii - upgrade
[Image: 03q8Fs6.jpg][Image: 4Jr4dQR.jpg][Image: k6v7Ls5.jpg][Image: qmwvGcL.jpg][Image: rZ98mBz.jpg]
Specs:- Professional Portafilter in brass chromed of the weight of 550 grams
- Group semiprofessional coffee in chromed brass
- 2 liters boiler in copper
- Circulation interchange thermosiphonic in copper (HX), the water disbursed for the coffee is not to direct contact with the water of the boiler but warms through a heat exchanger in copper . The water's temperature in the boiler is constantly regulated to 120° through an electronic circuit, this it allows to always have a continuous vapor to do savory and creamy cappuccino or to heat water.
- 3 Liters water tank container for the automatic filling of the boiler
- Simultaneous distribution of coffee and vapor
- Steam wand switable 360° (4 holes 1mm type NS MUSICA)
- Anti vacuum valve
- Gigleurs to improve thermal stability
- ABS Cupholder able to entertain up to 12 cups
- Body Stainless steel + ABS
- Water shortage indicator
- Heating-on indicator
- Timed dosing
- Soft touch bottons
- Discharge tank Capacity
RE: Vand Nuova Simonelli Oscar II - Rosu - bogdanjsx - 16-01-2020
Am trimis PM.
RE: Vand Nuova Simonelli Oscar II - Rosu - dinurm - 18-01-2020
Vandut la pretul cerut. Felicitari cumparatorului si sa-l foloseasca cu placere asa cum l-am folosit si eu :)
RE: Vand Nuova Simonelli Oscar II - Rosu - bogdanjsx - 18-01-2020
Confirm, espressorul a ajuns la mine. Multumesc pentru amabilitate, explicatii si rabdare!
