gooseneck kettle - Printable Version +- Forumul Espressoman - In cautarea espresso-ului perfect (https://www.espressoman.ro/forum) +-- Forum: Comunitatea de espressomani (https://www.espressoman.ro/forum/Forum-Comunitatea-de-espressomani) +--- Forum: Marketplace (https://www.espressoman.ro/forum/Forum-Marketplace) +---- Forum: Tranzactii incheiate (https://www.espressoman.ro/forum/Forum-Tranzactii-incheiate) +---- Thread: gooseneck kettle (/Thread-gooseneck-kettle) |
RE: gooseneck kettle - renatoa - 28-06-2018 Buna observatie... o sa pun o intrebare... Nu intotdeauna US plug inseamna 110V, poate am noroc... RE: gooseneck kettle - flipu2k - 28-06-2018 Intrebase cineva deja:
RE: gooseneck kettle - KrisssKros - 28-06-2018 Ia vedeti aici: https://www.amazon.co.uk/Homgeek-Gooseneck-Electric-Temperature-Control/dp/B079MF1SZQ/ref=sr_1_1_sspa?ie=UTF8&qid=1530190992&sr=8-1-spons&keywords=Bonavita+kettle&psc=1 Cam bun pretul... parca m-as baga si eu. Problema e ca nu trimit in Ro, dar cred ca e rezolvabil destul de usor acest aspect. L.E. Aici cu livrare in Ro https://www.amazon.de/dp/B075GRG92Y/ref=sxbs_sxwds-stvp_1?pf_rd_m=A3JWKAKR8XB7XF&pf_rd_p=233655306071036716&pd_rd_wg=EaSTv&pf_rd_r=4BSW5QGNZF60ZSED58J6&pf_rd_s=desktop-sx-bottom-slot&pf_rd_t=301&pd_rd_i=B075GRG92Y&pd_rd_w=yVTpr&pf_rd_i=bonavita+gooseneck&pd_rd_r=c2f22835-8c16-4f64-8579-56df4b26479c&ie=UTF8&qid=1530191834&sr=1 RE: gooseneck kettle - renatoa - 28-06-2018 Sincer si 160 lei mi se parea cam tichie de margaritar... doar pentru gatul ala de lebada, ca asa fierbatoare cu termostat cu display gasesti sub 100 lei... Astept sa aduca la barshaker :D RE: gooseneck kettle - MyR - 28-06-2018 (28-06-2018, 18:39)renatoa Wrote: Sincer si 160 lei mi se parea cam tichie de margaritar... doar pentru gatul ala de lebada, ca asa fierbatoare cu termostat cu display gasesti sub 100 lei...Doar sa clarificam: Link -- este la reducere inca 2 zile - pretul final pentru espressomani fiind doar 143.99 ron tva inclus ( 159.99 -10% ). Cu display in mod sigur nu aducem in viitor din mai multe motive. Pentru a avea control maxim la temperatura se gaseste gama hario temp. si modelel smart/artisan de la brewista... dar ele sunt recomandat pentru uz profesional. ( cel putin pretul lor sunt destul de mari pentru uz casnic ) Cred ca trebuie decis urmatoarele lucruri cand cumperi orice online/ofline: - cat de repede vrei produsul - cat esti dispus sa platest - ce servicii sales si after sales vrei ( livrare rapida, comunicare, amabilitate, garantie, etc ) - ce te determina sa cumperi ( impuls, oferta, vremea, pret, etc. ) - loialitate fata de marca, seller, producator, regiune, tara, orice. RE: gooseneck kettle - renatoa - 01-09-2018 A luat pana la urma cineva din UK kettle din asta ? (28-06-2018, 16:10)KrisssKros Wrote: Ia vedeti aici: gooseneck kettle - claudiur - 02-09-2018 Eu am comandat-o pe aceasta de pe aliexpress și a costat 105 RON. Încă nu a ajuns ca să pot zice dacă e ok sau nu, dar seamănă cu cea de pe amazon https://www.aliexpress.com/item/-/32861992015.html Sent from my SM-G960F using Tapatalk RE: gooseneck kettle - renatoa - 02-09-2018 E aceeasi, doar ca in discutiile de mai sus nu gasesisem decat US. Buna treaba... asteptam impresii RE: gooseneck kettle - claudiur - 19-09-2018 Am primit kettle-ul, acum o saptamana, dar nu am avut timp sa-l folosesc deoarece sunt plecat. In schimb, l-am testat putin sa vad cum e. Produsul a ajuns la vama dar nu am platit nimic in plus, pretul total fiind cel de sus, 105 RON. Scoate un sunet destul de tare cand incalzeste apa (mi se pare deranjant pentru colegi) si bipaie cand apas tastele pentru setarea temparaturii. Am observat ca daca setez la o anumita temperatura si activez functia hold, aparatul asteapta sa scada vreo 3-4 grade dupa care incalzeste la temperatura setata. Dupa ce se ridica din baza, isi pierde setarea de temperatura si daca vrei sa-l folosesti mai tarziu, va trebui sa setezi din nou temperatura. Am pus apa din el intr-un kettle Bonavita si indica cu un grad in minus. Cand ajung la birou voi face mai multe teste si chiar sunt curios care este diferenta de zgomot, la incalzire, intre cele doua. Multumesc, Claudiu RE: gooseneck kettle - Lyvyoo - 19-11-2018 Sexy mai este Stagg EKG dar si 200$ pentru un termoplonjon mai frumos.... gooseneck kettle - claudiur - 19-11-2018 Revin cu un mic update despre kettle-ul luat din China. Dacă setez o anumita temperatura, aparatul se oprește când ajunge la temperatura respectiva dar, din cauza inerției continua sa crească cu 2-5 grade. Dacă îl pun pe funcția hold, așteaptă sa scadă temperatura cu 2-4 grade după care începe sa încălzească și atunci iar trece de temperatura setata.. Sent from my SM-G960F using Tapatalk RE: gooseneck kettle - nechezol - 19-11-2018 M a tentat si pe mine cel de mai sus insa s au epuizat pana m am hotarat, ramasese doar cel US plug. Pana la urma am luat https://www.aliexpress.com/item/1L-1-2L-Fantastic-Kitchen-Stainless-Steel-Gooseneck-Tea-Pot-Pour-Over-Coffee-Water-Milk-Frothing/32949219761.html Pentru 60 lei retrasi de pe card e prea bun! RE: gooseneck kettle - renatoa - 19-11-2018 Trebuie vazut daca termometrul indica bine daca ai doar 1/4 din capacitate apa in el...
RE: gooseneck kettle - Zwanger - 19-11-2018 Al meu indica bine si cu 1/4 apa si cu 3/4. https://www.amazon.de/Handbr%C3%BCh-Kaffeekessel-aus-Edelstahl-aufgegossenen-Filterkaffee/dp/B077H8FT9H/ref=sr_1_1?ie=UTF8&qid=1542641366&sr=8-1&keywords=gator+kettle gooseneck kettle - Mihai L - 19-11-2018 Senzorul cred ca e jos. Apare insa o inertie termica, baza continua sa cedeze temperatura si dupa decuplare. RE: gooseneck kettle - Zwanger - 19-11-2018 Eu obisnuiesc sa-l umplu cu 350 ml de apa din care folosesc 230 grame pt V60 iar restul sa limpezesc filtrul/incalzesc recipientul de colectare. Oricum de fiecare data il golesc, nu reincalzesc apa in el. RE: gooseneck kettle - Dianette - 11-05-2019 UP: Incet-incet, imi dau seama cat de multe lucruri imi trebuie pentru o cescuta buna de cafea. Daca mai observati pe vreun site o oferta buna la un gooseneck kettle, va rog sa postati aici. Multumesc. RE: gooseneck kettle - lracu - 11-05-2019 Oferta similara cu cea de la inceputul thread-ului nu stiu daca mai gasesti. De la pret mic la pret mare: Cele mai ieftine, electrice, cu control temperatura, livrare din RO: https://www.klarstein.ro/Aparate-de-bucatarie/Fierbatoare-de-apa/Garcon-cazan-functia-gooseneck-1L-2000W-otel-inoxidabil.html https://www.klarstein.ro/Aparate-de-bucatarie/Fierbatoare-de-apa/Garcon-Pro-ceainic-volum-1-litru-1850-2200-w-otel-inoxidabil.html Urmatoarele, cu livrare din RO: http://barshaker.ro/Brew-Bar/Gooseneck-Kettles/Bonavita-Digital-Variable-Temperature-Gooseneck-Kettle-1l http://barshaker.ro/Brew-Bar/Gooseneck-Kettles/SmartPourKettle http://barshaker.ro/Brew-Bar/Gooseneck-Kettles/Felicita-Square http://barshaker.ro/Brew-Bar/Gooseneck-Kettles/Brewista-artisan-600ml-silver http://barshaker.ro/Brew-Bar/Gooseneck-Kettles/Brewista-artisan-gold ... Alta varianta, de cautat pe aliexpress ... --- despre Klarstein: https://www.espressoman.ro/forum/Thread-Setup-pentru-aeropress?pid=114140?highlight=klarstein#pid114140 iar despre Brewista si Bonavita sunt multe informatii, de ex. aici: https://www.espressoman.ro/forum/Thread-Kettle-cu-reglaj-de-temperatura?highlight=klarstein RE: gooseneck kettle - renatoa - 11-05-2019 Pe Amazon.de am mai vazut sub 20 eur cu livrare in ro cu tot. RE: gooseneck kettle - RaduNim - 12-05-2019 Salut! Klarstein am eu și sunt foarte mulțumit de el. Singurul inconvenient este faptul că dacă vreau 85 grade trebuie să setez 83 sau 82 deoarece nu se oprește fix temperatura. Raportul calitate/preț cred ca este destul de ok (12-05-2019, 09:21)RaduNim Wrote: Salut!În plus, are gâtul foarte subțire și ajuta foarte mult la precizie pentru V60 gooseneck kettle - Oly - 12-05-2019 Asta este principalul motiv pentru care nu am luat klarstein, ci hario bueno temperature control, care e undeva la 900 lei. Surpriza... si la hario creste temperatura dupa oprire. Insa daca il ridici si il asezi inapoi pe baza, iti arata temperatura finala (si cum scade, ulterior, cate un grad, pana la temperatura dorita). Sent from my mobile, using Tapatalk gooseneck kettle - Mihai L - 12-05-2019 ? Si la Klarstein arata temperatura. Si nu trebuie ridicat...[emoji3] RE: gooseneck kettle - Tiranator - 12-05-2019 Bonavita daca ii dai 94, la 94 se opreste, doar daca ii dai hold temperature sa zicem ca ti s-a racit apa cu 2 grade de la 94 la 92 el va urca undeva pe la 95 si trebuie sa astepti putin sa scada, ca si pret calitate se aflta in top, eu l-am luat la 420 de lei. RE: gooseneck kettle - Laddu - 12-05-2019 (12-05-2019, 16:05)Oly Wrote: Asta este principalul motiv pentru care nu am luat klarstein, ci hario bueno temperature control, care e undeva la 900 lei. Surpriza... si la hario creste temperatura dupa oprire. Insa daca il ridici si il asezi inapoi pe baza, iti arata temperatura finala (si cum scade, ulterior, cate un grad, pana la temperatura dorita). La mine se întâmplă asta doar pentru setările dub 90 de grade, iar abaterea e de aproximativ 2 grade. RE: gooseneck kettle - Dianette - 20-05-2019 Multumesc pentru raspunsuri! RE: gooseneck kettle - renatoa - 07-02-2020 Update Klarstein https://www.espressoman.ro/forum/Thread-Setup-pentru-aeropress?pid=129737#pid129737 RE: gooseneck kettle - marst - 05-05-2020 Ce mai recomandati in materie de kettle? Electric am inteles, e Bonavita - chiar si cu design-ul sau invechit - e best buy. Daca tocmai ai luat salariul si n-ai ce face cu el, cumperi si un Fellow Stag EKG. Dar daca nu prea mai ai loc pe blatul din bucatarie si pentru platforma de la kettle, ce recomandari exista dintre cele pentru plita? Preferabil sa sa fie in inox/otel inoxidabil si sa aiba termometru incorporat. As putea face si un compromis pentru Hario Buono si termometru separat, insa am dubii ca incape tija termometrului prin gaurile din capac. Alte recomandari? Multumesc RE: gooseneck kettle - vladdooo - 05-05-2020 doar Bonavita RE: gooseneck kettle - cradun - 05-05-2020 Eu am un Bodum electric plus termometru luat de la barshaker, am facut o improvizatie, sunt sigur ca merge si pentru un kettle de pus pe aragaz. Am scos manerul original si am marit gaura cu o surubelnita electrica si cu un burghiu. Prinderea in partea inferioara a capacului am facut-o taind suportul cu care venise termometrul. ![]()
RE: gooseneck kettle - Lucian. - 05-05-2020 (05-05-2020, 16:57)marst Wrote: Ce mai recomandati in materie de kettle? Electric am inteles, e Bonavita - chiar si cu design-ul sau invechit - e best buy. Daca tocmai ai luat salariul si n-ai ce face cu el, cumperi si un Fellow Stag EKG.S-a mai discutat pe forum. Uite asta (https://www.electrocasnicediscount.ro/ibric-de-cafea-pentru-aragaz-vonshef-1000088--termometru-inclus--capacitate-12-litri-/5480.htm) cred ca e cel mai ieftin de pe la noi cu termometru. Eu nu-l am pe asta, dar cei care l-au cumparat au zis ca este ok. |
