Donez Niche Flow Control Disc
Exclamation
Donez Niche Flow Control Disc.
Pentru cine nu stie ce este:
The Niche Flow Control Disc is a simple after-market installation for first generation Niche Zero grinders. Please note that current Niche Zero models come with the Niche Flow Control Disc pre-installed.
The small (40mm), clear disc is made from food grade polycarbonate. When installed into the bean funnel, the Niche Flow Control Disc prevents 'pop-corning' - coffee beans jumping around the funnel prior to being fully fed into the burrs.
Because the Niche Flow Control Disc feeds beans into the burrs at a steady pace the grind consistency is also improved.
[Image: y4LnAJU.jpg]
Vibiemme Super 2B/PID, Honne/Arco, Bullet R1 v2
Prev: Breville BES920XL 2B, Niche Zero, K30, KN-8828B-2K+
Prev: LaSpaziale S1 Vivaldi II, Mazzer Mini E, Baratza Sette 270W, Kinu M47
Interesat.
Scriu in privat
(08-04-2023, 20:21)N3cks Wrote: Interesat.
Scriu in privat
Ti-am raspuns in privat pe 10 aprilie...
Ohhh…
Mi-a scăpat!
Mersi!
Trimis catre @N3cks, se poate inchide.
