Vand setup complet [ Expobar Brewtus IV + Eureka Mignon SD + carucior bucatarie ] - Printable Version +- Forumul Espressoman - In cautarea espresso-ului perfect (https://www.espressoman.ro/forum) +-- Forum: Comunitatea de espressomani (https://www.espressoman.ro/forum/Forum-Comunitatea-de-espressomani) +--- Forum: Marketplace (https://www.espressoman.ro/forum/Forum-Marketplace) +---- Forum: Vanzari espressoare, rasnite si accesorii (utilizate) (https://www.espressoman.ro/forum/Forum-Vanzari-espressoare-rasnite-si-accesorii-utilizate) +---- Thread: Vand setup complet [ Expobar Brewtus IV + Eureka Mignon SD + carucior bucatarie ] (/Thread-Vand-setup-complet-Expobar-Brewtus-IV-Eureka-Mignon-SD-carucior-bucatarie) |
Vand setup complet [ Expobar Brewtus IV + Eureka Mignon SD + carucior bucatarie ] - D.Lali - 30-11-2023 Vand setup-ul de mai jos:
- Are pompa noua, instalata in urma cu cateva luni. - flow control Profitec - add-on pulsor pentru reducerea zgomotului pompei vibratoare. - showerhead IMS pro - duza abur Tidaka 4 gauri
- Distribuitor Palm Tamper - 58.5mm - Dosing ring cu magnet ø 58mm - Inox - Puck Screen - 58.5mm - Sita Blind ø 70x17 mm - 58mm - RDT tool - Fellow Atmos Vacuum Canister - 0.7l Matte White Steel - Perie Curatare Steamer - Urnex - 25 cm - Portafiltru fara fund - WDT tool - Tamper Motta 58mm - Tamper Autonivelant 58.5 mm - Inox and Black Preturi:
Pentru orice alta informatie/video/test va rog sa imi scrieti si rezolvam. RE: Vand setup complet [ Expobar Brewtus IV + Eureka Mignon SD + carucior bucatarie ] - D.Lali - 25-02-2024 Anuntul este in continuare valabil. RE: Vand setup complet [ Expobar Brewtus IV + Eureka Mignon SD + carucior bucatarie ] - D.Lali - 15-05-2024 (30-11-2023, 15:39)D.Lali Wrote: Anunta inca valabil, preturi reduse: |
