Vand rasnita Vario Home Mahlkönig - Printable Version +- Forumul Espressoman - In cautarea espresso-ului perfect (https://www.espressoman.ro/forum) +-- Forum: Comunitatea de espressomani (https://www.espressoman.ro/forum/Forum-Comunitatea-de-espressomani) +--- Forum: Marketplace (https://www.espressoman.ro/forum/Forum-Marketplace) +---- Forum: Tranzactii incheiate (https://www.espressoman.ro/forum/Forum-Tranzactii-incheiate) +---- Thread: Vand rasnita Vario Home Mahlkönig (/Thread-Vand-rasnita-Vario-Home-Mahlk%C3%B6nig) |
Vand rasnita Vario Home Mahlkönig - mliviu86 - 28-11-2020 Vand rasnita Vario Home Mahlkönig cumparata in Noiembrie 2019 de Black Friday pe Espressoman la pretul de 1800 lei, de la caffea.ro. Am factura si pachetul complet original. Am servisat-o in iulie 2020 la vanzator si recalibrat lamele. Folosita in regim de 2 duble pe zi, principal pentru espresso, doar cu cafea de specialitate. In jur de 15kg de cafea boabe macinate. Motiv vanzare upgrade. Pret 1300 lei Idle speed: 1000 rpm Grinding disc diameter: 54 mm / 2.12 in Grinding disc material: Ceramic Average grinding capacity*: ca. 1.6 g / s Hopper capacity: ca. 200 g / ca. 0.44 lb Max. nominal power: 180 W Dimensions (w x h x d): 13 x 37 x 18 cm Dimensions of packing (w x h x d): 37 x 60 x 40 cm Net weight: 4.2 kg Gross weight: 5.4 kg Coarse and fine tuning with over 200 grind adjustments LCD-Display Coarse and fine tuning with over 200 grind adjustments ![]() ![]() ![]()
RE: Vand rasnita Vario Home Mahlkönig - solaris78 - 29-11-2020 Salut. Sunt interesat. Ti-am dat PM RE: Vand rasnita Vario Home Mahlkönig - solaris78 - 02-12-2020 Salutare. Eu m-am retras din tranzactie din motive personale, independente de produsul vandut. Un UP! si multumiri lui Liviu pentru disponibilitate si ajutor. Poate data viitoare ![]() Succes la vanzare in continuare! RE: Vand rasnita Vario Home Mahlkönig - mliviu86 - 06-12-2020 Anunt valabil RE: Vand rasnita Vario Home Mahlkönig - mliviu86 - 16-12-2020 Up. Inca disponibila, includ si o cheie de desfacut lamele. RE: Vand rasnita Vario Home Mahlkönig - mliviu86 - 17-12-2020 raduxxm ai mesajele private dezactivate, nu iti pot raspunde "raduxxm has private messaging disabled" RE: Vand rasnita Vario Home Mahlkönig - mliviu86 - 23-12-2020 Rasnita a fost vanduta lui 1naCa. Pretul 1300 lei. Se poate inchide topicul. |
