La Marzocco Swift Mini (cu mecanism Etzinger) - Printable Version
+--- Thread: La Marzocco Swift Mini (cu mecanism Etzinger) (/Thread-La-Marzocco-Swift-Mini-cu-mecanism-Etzinger)
La Marzocco Swift Mini (cu mecanism Etzinger) - maki - 20-10-2019
noua rasnita LM destinata mai mult pentru acasa, care pe langa rasnire, cantarire mai si tampeaza.
[Image: plcA536.jpg][Image: m1U9RSe.jpg][Image: vNWb63I.jpg][Image: bI4WCuU.jpg][Image: UcOO0lW.jpg]
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - Ciprian75 - 20-10-2019
genial, o fi si pe 54? ce pret are?
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - MyR - 20-10-2019
Deja este pus pe siteul lamarzocco home, 1615
https://international.lamarzoccohome.com/it/swift-mini/
https://international.lamarzoccohome.com/it/categoria-prodotto/grinders/
(20-10-2019, 11:27)MyR Wrote: Deja este pus pe siteul lamarzocco home, 1615
fara TVA ... sunt curios cat de fiabila va fi avand in vedere ca macina, cantareste si tampeaza ...
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - slavic1983 - 20-10-2019
Daca shpache-uieste cineva niste Deutsch-eza sa ne traduca: https://youtu.be/NOOuZF5r6xI
La Marzocco Swift Mini (cu mecanism Etzinger) - mirceat - 20-10-2019
Nu a spus ceva important (edit se refera la urmatoarea rasnita cred - ca retentia ar fi sub 1gr) . In urmatorul clip arata cum se poate rasni fara tampare, rasucind capacul de deasupra, cam la min 6:20 https://youtu.be/dBUA72IpMKM
Se vede jos in interiorul rasnitei un tamper melcat, probabil tampeaza prin rasucire.
Interesante lucruri prin targ. Espressorul cu inductie de la Carimali, tehnologie boilerless, suna promitator.
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - Lyvyoo - 21-10-2019
Sa nu ne bucuram prea devreme :)
- reglaj steppED (in trepte)
- cutite... "32mm conical steel burrs designed by us- fast grinding while limiting heat and minimizing retention."
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - maki - 21-10-2019
(21-10-2019, 10:55)Lyvyoo Wrote: - cutite... "32mm conical steel burrs designed by us- fast grinding while limiting heat and minimizing retention."
https://etzinger-ag.com/blog/32mm-so-what
Nu cred ca este Etzinger vreun etalon de performanta in materie de cutite lucrate la finete care sa asigure randamente de extractie superioare (gen SSP, Mahlkonig, Compak) si sa te faca sa scoti banutul din buzunar cu mai mult avant.  Desi e un producator ok, cu roboti industriali, extrem de potent dpdv al productivitatii. Acel articol trebuia sa aiba inserate tot felul de grafice cu analize laser comparative ca sa aduca mai multe argumente. Pentru ca in fond, va dati seama ca rasnita din topic nu cred ca va cobori sub 2000E.
(21-10-2019, 13:38)Lyvyoo Wrote: va dati seama ca rasnita din topic nu cred ca va cobori sub 2000E
€1.615,00 VAT Excluded
Merci de update!
Am gresit cu 80E  :))
cateva beri bune-bune :D
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - maki - 22-10-2019
iata si un video cu aplicatie.
cutitele par foarte foarte similare celor de pe Sette
La Marzocco Swift Mini (cu mecanism Etzinger) - dev - 22-10-2019
S-au hotărât de deghizeze etzmax-ul, care probabil se vinde in cantități numărabile pe degete, și să-l arunce în curtea LM.
Poate totuși se ambiționează un producător sa scoată un echivalent pentru Niche, cu cuțite plate, sub 1000 de euro. Sau un Honne ceva mai bine capitonat și cu aspect mai casnic.
nu stiu de ce va uitati asa rau la cutitele Etzinger, imi pare nefondat.
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - renatoa - 22-10-2019
Nu pica bine la religie partea cu "size doesn't matter"... ;)
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - maki - 24-10-2019
au aparut filmulete, gen
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - renatoa - 24-10-2019
... nu mai zic ca se compara mere cu ... ananas...
32 de la etzinger nu trebuie comparat cu 47 de la Kinu, ci cu 28, care este diametrul cercului de iesire...
Nu pricep de ce la conice o ard in continuare cu numere mari, cum ar fi diametrul exterior al statorului, dar total irelevante... adica pricep, marketing, numerele vinde... dar aici ma asteptam sa se fi desteptat lumea...
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - Ciprian75 - 24-10-2019
Oare este adaptabila si pentru alte portafiltre? ...
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - radudani - 24-10-2019
Quote:32 de la etzinger nu trebuie comparat cu 47 de la Kinu, ci cu 28, care este diametrul cercului de iesire...
dantura Etzinger - daca se pot face analogii cu Sette - nu poate fi comparata decat tot cu danturi Etzinger!
am 'parcurs' 3 Sette-uri - asta pentru a-mi argumenta zicerea! parere personala, oricum!
si mai stim ca la Sette, sau alte noi rasnite Etzinger, se practica un sistem functional invers la cutitul de angrenare boabe (cel rotitor); deci 'diametrul statorului', e diametrul exterior al rotorului!
si sigur, profilele cutitelor difera radical fata de cele de la cutitele stock ale rasnitei Kinu...
si sigur, difera si viteza - cea a lui Sette, cu cutite Etzinger e neobisnuit de mare pentru o rasnita cu 'dantura' conica, si capabila espresso...
iar cele chart-uri si analiza distributiei dimensionale a particulelor la Swift Mini (facute nu cu site ci cu refractometrie laser), daca au sa apara, ar trebui solicitate - sunt deja ani buni de cand am zis prima data - si pentru rasnita manuala preferata a forumului!
intru sustinerea atator afirmatii avantate despre performantele sale...
RE: La Marzocco Swift Mini (cu mecanism Etzinger) - dobrecatalin86 - 11-12-2023
Salutari!
Am o rasnita Swift Mini folosita vreo 4 ani. Eu am primit-o recent, cam de 2 luni si a mers perfect pana azi.
S-a blocat la un moment dat, motorul mergea in gol, fara sa mai rasneasca si a iesit fum din ea/din motor. Stiu sigur ca nu a mai fost stricata si reparata in trecut.
Aveti idee de un service in Romania? Sau poate chiar in Cluj? Sau de o persoana priceputa?
Nu ma pricep si nu prea vreau sa ma bag eu sa o desfac :D
Catalin
