Rasnita KOPI Deva - Printable Version
+--- Thread: Rasnita KOPI Deva (/Thread-Rasnita-KOPI-Deva)
Pages: 1 2 3
RE: Rasnita KOPI Deva - renatoa - 02-05-2021
(02-05-2021, 12:35)distrugatorul Wrote: Nu inteleg de ce o comparati doar cu honne? Ce are in minus rasnita asta fata de o eureka xl spre ex.? Sau fata de o alta rasnita care are doar cutite plate. In plus e evident ca are modul diferit de eliminare a macinaturii.
Si mai are in plus o idee de single dose fara burdufuri si pufaitoare
Pai tocmai astia sunt factorii care o fac sa fie comparabila in primul rand cu Honne. Pe langa modul de alimentare cu boabe, transmisia de la motor la cutite...
Marimea cutitelor este ultimul factor de luat in seama, 64 a devenit acum "the new black".
Mai important este ce urmeaza de la cutite incolo... pana in PF.
RE: Rasnita KOPI Deva - distrugatorul - 03-05-2021
Va fi lansata pe 31 mai pe kickstarter
https://www.kickstarter.com/projects/kopiconcepts/kopi-deva-a-single-dose-coffee-grinder
RE: Rasnita KOPI Deva - renatoa - 03-05-2021
Brandon Wong, Oxford, UK
Well... unde zicea ca rasa galbena... o sa ne faca cafeaua intr-o zi ? :D
RE: Rasnita KOPI Deva - distrugatorul - 09-05-2021
oare o fi asa??
[Image: 0Loqx6n.jpg]
iar asta e review-ul lui Josh Williams:
When I first took the Deva out of the box, I could tell this was a serious bit of kit.
It's build is beautiful (and this is the prototype)
I'm not one for looks anyway but it's very nice to take photos of.
The little details like the walnut on the grinder and the tamping station are ?
But I'm here to look at how it performs!
Battery - very unusual but I dig it. 2 hour battery life which is a long time for someone to stand there and test ? however, the lack of wires is beautiful. I didn't realise how much this makes a difference ?
Retention - KOPI say its less than 0.2g and I've done 54 coffees (time of writing) and I agree. One of the coffees was 0.4g the rest were 0.2 with a few 0.1g.
RPM - this is an amazing touch that you can play around with using a dial on the side. Grind size needs to be adjusted as you change RPM. 200-1000 RPM
Grind Adjustment - easy to do. Fine and Coarse is engraved on the grinder, turn to what you need.
Filter and Espresso - Yes and with ease. I'm not going to lie, I struggled at first getting the right grind for espresso but after a quick chat with the team at KOPI Concepts, I made an amazing espresso! Filters are easy to do as well and I've had amazing results so far.
With all the good, there are a few things that I would like to see differently (some of these mentioned are getting updated)
Dosing Funnel needs to be slightly bigger as grounds shoot out (got messy so just lifted Portafilter closer)
RDT method is a must - it causes static (like most grinders of this quality) but 3 sprays and your safe.
The on button is in an awkward position but it's not a big issue but I thought it needs to be mentioned.
It is an amazing grinder, with a lot to offer, especially for it's price and size.
If I had to compare it's performance to any grinder, I would say an EK43 - it's that good.
RE: Rasnita KOPI Deva - renatoa - 09-05-2021
Si chiar va asteptati ca, in orice bransa, cineva care vrea sa lanseze ceva nou, sa nu isi laude creatia ?
Daca ar fi sa facem o paralela, pai atunci ar insemna ca celui cu Flair 58 aproape ca ii e jena de ce a facut, doar ca nu isi cere scuze... la cat de timid prezinta orice aspect pe net...
O anumita parte a pietei... forum(m)istice :) chiar din excitari din astea traieste, daca admonesteaza pe cei de la Arco ca a trecut o luna si nu au dat raportul cu ce mai e nou.
Personal sunt genul "cand vine, vine... dar sa fie bine" :)
Quote:RDT method is a must - it causes static (like most grinders of this quality) but 3 sprays and your safe.
Asta cu bold suna foarte versatil... fiecare crede ce vrea  :D
Deci nu e pentru cei care urasc RDT. Mie imi place.
RE: Rasnita KOPI Deva - renatoa - 31-05-2021
S-a lansat...
Neinspirat termen de livrare, de Craciun... acum toti o sa viseze sa o aiba sub pom...
RE: Rasnita KOPI Deva - distrugatorul - 31-05-2021
Mi se pare de bun simt ca s-au gandit si la clientii non UK care trebuie sa plateasca taxe vamale si au pus un pret mai mic cu 100 lire. :D
Ce kopi..l esti... :D
Ei de fapt s-au gandit sa dea in cap la Niche ;)
RE: Rasnita KOPI Deva - dev - 31-05-2021
Din partea mea, sa fie primii din cat mai multi...
RE: Rasnita KOPI Deva - vlaicu - 31-05-2021
(31-05-2021, 11:27)distrugatorul Wrote: Mi se pare de bun simt ca s-au gandit si la clientii non UK care trebuie sa plateasca taxe vamale si au pus un pret mai mic cu 100 lire. :D
N-au facut nimic special. Nu au inclus TVA-ul. Practic il platesti la destinatie + eventualele taxe de import. Am vazut ca Romania are 2% taxe. Se mai adauga... fix 96.39 Lire la pretul curent. Adica ajungi la pretul de UK.
Cand se va ajunge la import trebuie sa fim atenti cu ce operator ajunge. Daca ajunge prin DHL, TNT, etc, fie aveti cod EORI fie le mai dati baietilor 100RON+ sa faca ei vamuirea.
Codul EORI se obtine relativ facil si il poti solicita pe intreaga perioada a actului de identitate, eu asa am facut. Ah, si nu costa nimic, doar timp si putini nervi (mai ales daca nu ai Windows, sau asa a fost "pe vremea mea", acum 2 ani si jumatate cand l-am solicitat)
Nu e ceva special dar magarii de la Niche nu au facut nici macar atat.  Si nu doar Niche. Majoritatea producatorilor din afara UE
RE: Rasnita KOPI Deva - zmolk - 31-05-2021
(31-05-2021, 11:52)vlaicu Wrote: Codul EORI se obtine relativ facil si il poti solicita pe intreaga perioada a actului de identitate, eu asa am facut. Ah, si nu costa nimic, doar timp si putini nervi (mai ales daca nu ai Windows, sau asa a fost "pe vremea mea", acum 2 ani si jumatate cand l-am solicitat)
S-a simplificat mult acum, se face cererea online, direct pe site, apoi se trimite (+ CI) direct pe mail.
Aprobarea a venit si ea instant, in 2-3 ore, cand am facut anul acesta.
RE: Rasnita KOPI Deva - renatoa - 08-06-2021
Incepe sa se tureze... si cu rele si cu bune...
https://www.instagram.com/p/CPvhqTRt5XK/
RE: Rasnita KOPI Deva - renatoa - 13-07-2021
Doua zile au mai ramas, de luat la pret redus... tic, tac...
RE: Rasnita KOPI Deva - distrugatorul - 13-07-2021
pai daca se scumpeste chiar ca nu o mai ia nimeni  :D
Rasnita KOPI Deva - vlaicu - 13-07-2021
Știi vreo rasnita cu motor DC și reglaj variabil al rotatiei, cuțite plate, SD la 3000ron?
Nu.
Asa este ai dreptate. Dar cu toate astea se straduieste din greu sa depaseasca pragul de 100000 euro. Nu am idee ce lipseste. Probabil strategia de marketing. Dupa atata vreme de la lansare are doar 120 de cumparatori
Pai na, rămâne de văzut. Pana acum review-urile nu sunt rele.
(13-07-2021, 20:17)vlaicu Wrote: Știi vreo rasnita cu motor DC și reglaj variabil al rotatiei, cuțite plate, SD la 3000ron?
D/C este alegerea fireasca daca vrei tensiune mica si turatie variabila, in A/C e mai complicat/costisitor de facut, cel putin pentru motoarele cu inductie (a)sincrone. Pentru cele cu perii e la fel de simplu de facut si pentru A/C ca si pentru D/C, un dimmer.
Si autorul impinge in fata reglajul turatiei ca selling point principal:
Quote:The KOPI Deva is currently the only grinder with adjustable RPM priced below £1100.
... dar sincer eu nu il percep ca o necesitate, daca era ar fi fost cerut de piata si perceptibil in rezultate, de mult  era mainstream, pentru ca repet, nu e greu de facut si nu e scump.
La naiba, putina logica, motorizarea care o are el acolo se gaseste in orice bormasina de 24-40Nm, cu acumulator, care o gasesti de la vreo 300 lei in sus !
Referitor la partea cu "mai tarziu va fi mai scump" am revazut proiectul si vad ca autorul nu avanseaza un pret de lista post-KS, asa ca s-ar putea ca pretul actual sa ramana, daca ii permite viabilitatea afacerii.
Rasnita KOPI Deva - vlaicu - 14-07-2021
Cred ca am mai discutat despre faptul ca piața de acasă este în mare parte ignorata. De-abia recent vad companii care încearcă sa se adreseze utilizatorului de acasă cu produse mid-high. Dacă la espressoare am avut variante la rasnite, nu prea. Iar monolith și cele similare sunt în alta liga de pret.
Nu cred ca se poate ignora total importanta ajustării rotatiilor, unde nu ai profil pe cuțit sau construcție specifica mai compensezi prin evitarea pop-ingului.
In fine, vedem. Mie personal îmi place.
RE: Rasnita KOPI Deva - sochaux_ - 21-12-2021
Poate prezintă interes aici, pentru cine nu le-a văzut deja:
RE: Rasnita KOPI Deva - cristian88 - 13-03-2022
Am înțeles ca in Martie se livrează primele comenzi. A primit careva? Și dacă da, cum i se pare? Eu am dat comandă si îmi vine in luna Mai de-abia.
Rasnita KOPI Deva - vlaicu - 13-03-2022
Încă nu am primit notificare ca a început expedierea. Ultima data încă așteptau după motoare.
[Image: 1150854cf00ae9a6eec1e68d52179670.jpg]
RE: Rasnita KOPI Deva - cristian88 - 14-03-2022
(13-03-2022, 21:56)vlaicu Wrote: Încă nu am primit notificare ca a început expedierea. Ultima data încă așteptau după motoare.
[Image: psTYavJ.jpg]
Rasnita KOPI Deva - vlaicu - 23-05-2022
Azi am primit râșnița după ce am plătit taxele vamale, tva și ce-a mai dorit ups-ul.
Am făcut 2 shot-uri deci nu am cum să mă pronunț.
Motorul este super silențios. Nici râșnirea nu este cu mult mai zgomotoasă decât o manuală, aș zice. Dar la rotațiile recomandate (300rpm sau pe acolo) durează cam cât se estimează (ceva zeci de secunde).
[Image: Zj2EHB5.jpg][Image: R7xvdvs.jpg][Image: j19tZk6.jpg][Image: IeXuIJ0.jpg]
RE: Rasnita KOPI Deva - cristian88 - 23-05-2022
(23-05-2022, 21:26)vlaicu Wrote: Azi am primit râșnița după ce am plătit taxele vamale, tva și ce-a mai dorit ups-ul.
Sa o stapanesti sanatos!
 Este superba! A mea sosește in August.
Poti sa-mi spui te rog cat ai platit taxele?
Mda, puțin exagerat.
22% tva + 3% taxa pe import electronice + vreo 15€+TVA vămuirea făcută de ups
In total 155€
Asta la importul in Italia.
La importul in Romania probabil 19% și dacă ești pregătit sa îți faci singur vama atunci mai scutești niște bani.
Ca să obții dreptul (parca se cheamă cod EORI) de a face asta e un proces, nu mai știu acum cum este, eu l-am făcut acum vreo 3 ani și ceva.
Rasnita KOPI Deva - Kosti - 23-05-2022
Cat a costat? Și se unde ai luat-o?
(23-05-2022, 23:04)Kosti Wrote: Cat a costat? Și se unde ai luat-o?
A fost pe https://www.indiegogo.com la 500 lire pentru cei din afara Uk si 599 pentru cei din UK.
+ Taxe
Rasnita KOPI Deva - vlaicu - 31-05-2022
Încă nu am foarte multe de spus, am scos și shot-uri foarte gustoase dar și proaste. Pentru ca macinatura este mai pufoasa trebuie sa îmi ajustez metoda de preparare a puc-ului pentru ca uneori aceasta este sursa problemei.
Dacă macin la 300-400rpm, pentru 19 grame de cafea (de la Gardelli, deci destul de dură) îmi ia aproape 1minut.
Daca măresc rotațiile câștig timp dar am și mai mult finess. Deocamdată o am asa.
La 200 se întâmplă să "agate". Pentru o fracțiune de secunda se oprește iar mecanismul acela care asigura un rpm constant probabil ca întra și aloca mai mult curent motorului. De blocat nu s-a blocat niciodată dar la minimum de rotații mai face asa. Asta la boabele de la Gardelli. Pe cele de la sloane/dropshot, nu am problema asta.
E ușor de curățat și are o retenție de 0.3g as zice.
Pare bine închegată. La o comparație cu pl72, aceleași boabe (lelit ul cu hopper ul peste jumătate) am avut mai multa claritate în kopi. Curgerile au fost relativ apropiate dar nu identice. Nici nu cred ca as avea cum sa le fac identice pentru ca au grade diferite de finess, cel mai probabil.
Nu am testat v60 cu ea dar aștept niște cafea la degazat.
Referitor la preț, am intrat pe Kickstarter anul trecut pentru £459 + £30 transport la care s-au adăugat taxele de import de €155
