Noul Dual boiler de la Lelit PL162T Bianca - profilare de debit prin paddle
Muresan Radu Mar 26, 2019
in economic mode, after turning on, the pid temperature reaches 120 degrees. If the lever is lifted immediately after turning on the device, the temperature stabilizes to a set value pid.
Lelit
Mar 26, 2019Lelit Care
Hi Muresan, If, after turning on the machine, the temperature is below 70°C, will start the heating (without pid control) of the coffee boiler until reaching the set-point of 130°C. For the entire duration of the heating cycle, the display will shows the real temperature only if the TR:1 has been selected.) This heating cycle allows to reduce the time to reach the proper temperature of the brewer and ensures the first coffee extraction at a proper brew temperature. The same heating cycle occurs also if the Eco mode has not been selected. At your disposal for further information Best regards Riccardo Rossi
Muresan Radu
I've attached a movie to youtube. is it normal that the temperature does not stabilize and there is much steam when the lever is lifted? thank you very much for your answer.
Lelit
Mar 26, 2019 Lelit Care
Yes, I saw the video. The machine will be ready to dispense coffee when the temperature value shown on the display will stop to flashing. In the first part of the heating cycle, the machine reaches the set-point of 125/130C, and then the heating will be disabled (coffee boiler heating element not powered). The temperature will be gradually reduced until the programmed set-point (95C) is reached and the flashing will stop. Best regards Riccardo Rossi
Lelit Mara pl62 t Honne by Hedone Lelit pl162 t Bianca Bravo tools
Se cam pupa cu ce am intuit eu. Cine vrea sa nu respecte regulile oricarui E61 sau "E61 like" va profita din plin de incalzirea aceasta accelerata. Eu pe Brewtus cand am facut asta de doua ori in viata, adica sa fac espresso dupa 15min., am baut cele mai acre shot-uri posibil (desi PID arata 92 sa spunem).
Cine are rabdare 30-40 min. cu grupul E61, va regasi pe PID temperatura setata, dincolo de aceste oscilatii de inceput. Deci daca ai radare pur si simplu nu te intereseaza. Daca nu ai rabdare atunci ai ocazia sa bei un espresso cu aparatul mai fierbinte decat un DB cu E61 normal, insa nestabilizat, caci E61 nu stie d'astea cu 15-20 min Smile
Salutare!
A cam trecut ceva timp de cand sunt in posesia lui Lelit Bianca si ma bate gandul de o decalcifiere.
Vin de pe un Lelit PL41TEM unde era o operatie relativ simpla.A mai facut cineva detartare pe Bianca pana acum ?
Lelit Bianca PL162T,Mahlkoning Vario,Tamper Concept Art Dinamometric,Motta Europe Pitcher,Aeropress,Hario Skerton,Bialetti Moka Express
Nu e cazul. Daca ai folosit o apa ok poti sta ani buni de zile fara decalcifiere, care se face oricum in service.
Asa banuiam si eu .Multumesc de clarificari. Apa doar Bucovina am folosit pana acum
Ce sa fie ce sa fie?? Ma trezesc cu "mizerie"  cand vin de la munca ....
[Image: ImSYyM1.jpg]
Lelit Bianca, Macap M24M, , Lelit Pl481A, PL121 plus, Acaia Lunar.
Past: Lelit PL81T, Hario Skerton
Cu Brazilia/Columbia/Uganda blend prăjită de mine.
https://youtu.be/GP3Jv0ET1oA
Lelit Bianca PL162T, Lelit PL72 William, Kinu M47, Gefu hand grinder, Rok espresso maker, Aeropress, Hario V60, Wega HX, LaCimbali Max, Gene CBR 101, Lavazza Guzzini.
(12-04-2019, 13:36)mihneasusan Wrote: Cu Brazilia/Columbia/Uganda blend prăjită de mine.
Super! Sa treci pe la casieria Hedone Smile
ECM Classika PID / Eureka Mignon Specialita / Kribli-Grabli / Bravo tools & Gaggia Classic 2015 / MDF / Motta tools
(20-11-2018, 17:57)organon Wrote: Da, cu priza programabila e ok. Eu am un well pe care il folosesc permanent si de care sunt foarte multumit.
Va salut!
Proaspat posesor de espressor Bianca.
Am pus o priza programabila care porneste la 7 am astfel incat in jur de 8 sa pot face cafeaua.
Mai beau o cafea pe la 1pm si pe la 5-6 seara approx.
La 7 pm priza se opreste.
E ok sa il las 12h pornit sau ar trebui sa mai setez cateva intervale? (nu e activat stand by/economic)
(asta daca ajung la o intelegere cu jumatatea ca nu vrea cafea in afara "programului")
(10-05-2019, 08:56)ccosma Wrote: E ok sa il las 12h pornit sau ar trebui sa mai setez cateva intervale? (nu e activat stand by/economic)
Eu zic ca e mai ok sa mearga fara oprire 12 ore decat cateva cicluri on/off (care mai streseaza putin componentele cu dilatare/contractie termica). La consum oricum nu e diferenta.
Brewtus | Honne | AeroPress | Aergrind
Superba filmarea
Mulțumesc. Robusta a dat o cremozitate și culoare superbă extracției. Gustul nu a fost afectat extrem dar pe o Kenia sau Guatemala light pe care le-am mai încercat extracția din punct de vedere vizual era mult mai plată.
Va salut!
Revin cu o intrebare care s-a mai pus cateva pagini mai in spate dar nu am vazut vreun raspuns: voi folositi sita cu care a venit Bianca sau alte site? Daca folositi altele, puteti face cateva recomandari?
Ai doua optiuni, VST - hasbean.co.uk sau IMS - de cam oriunde, cauta le si vezi diferentele. Nu stiu cu ce vine Bianca, nu cred ca cu vreo una dintre ele oricum.
Dalla Corte Mina - Mythos SSP
Rasnite la vanzare: Mazzer Robur - Dalla Corte One
Am observat ca steamarul de la Bianca nu prea e "cool touch". Adica de la a doua frotare cam arde la degete. E normal sau e posibil sa se fi intamplat ceva?
Bianca, Kinu M47, Honne
Cred ca cel mai bine e sa scoti de tot acel plastic ce face orice espressor "cool touch"  si sa pui un manson de cauciuc. Chair discutam mai demult in forum si parea ca aburul e de o calitate mai buna cand nu este obturat de diverse astfel de sisteme.
O întrebare pentru posesorii onești, dispuși să recunoască eventualele minusuri ale espressorului lor:
Cum stă Bianca la capitolul stabilitate termică? Mă refer la situația destul de realistă în care trebuie să faci 5-7 cești în cursul unei întâlniri cu prietenii și dacă între shoturi trebuie să aștepți minute (zeci de secunde, nu știu), ca temperatura setată să fie exact cea afișată, real time, pe PID. Se pot face 5-7 shoturi, continuu, fără pauze (în condițiile temperaturii constante)?
Mulțumiri.
Lelit PL41 TEM, Eureka Olympus 75 E, hi-speed
Nu. Cred ca e nevoie de 15 sau 20 de secunde. E facut pentru experiment in exploatare nu pentru anduranta, sau uz comercial. Asta e sigur. Dar mai bine incerci cafele cat mai bune prajite light si te bucuri de ceea ce are deosebit, versatilitatea extraordinara de profilare.
LELIT Bianca ,Honne
Pai curatat, macinat cafeaua, cantarit, tampat... tot cam in 15-20s ajunge.
Quamar M80DR, M47 Phoenix, ex-M38, ex-PL043MMI, Brikka, ibric, AeroPress... and V60/Hario Buono
Ar trebui sa fie la fel ca la orice alt e61, de ce ar fi diferit?
Pe de alta parte nu cred ca avem vreun utilizator de Bianca cu dispozitiv scace pentru măsurare.
Brewtus IV | Eureka Olympus 75
Cand am avut acel eveniment vara trecuta am masurat la plecare si stabilitatea termica, folosind un scace, cel al lui Razvan de la Dalla Corte, insa avea un fir desprins si facea figuri. Cat s-a putut citi si a stat firul la locul lui, aparatul s-a comportat foarte bine, fara scaderi de temperatura bineinteles. De fapt orice grup E61 asta face, daca are la baza un Dual Boiler - dupa un flush de uniformizare de 3-4 secunde, in momentul in care incepi extractia temperatura va avea creste putin fata de punctul setat de tine.
Mai jos un clip cu un dispozitiv tip SCACE pe Bianca, aparat ce pare sa fie mai stabil decat Brewtus-ul pe SCACE. Faceti abstractie de temperatura de pe PID, care trebuie corectata din setari cu un offset de minus doua grade, si urmariti display-ul tester-ului. Imediat dupa stabilizare, variatia in jurul temperaturii de 94 de grade este de 0.3 grade in jos si in sus:
