Minimoka GR 0203
Salutare colegi cafengii!
Cautand rasnite am gasit Minimoka GR0203..1200 ron, 700 rpm, micrometrica
Are cineva aceasta rasnita?sau macar stie cineva daca merita cumparata?
(04-10-2015, 18:31)Wildfire Wrote: Salutare colegi cafengii! Cautand rasnite am gasit Minimoka GR0203..1200 ron, 700 rpm, micrometrica Sunteti cineva this rasnita? Sau macar stie cineva DACA merita Cumparata?
Am impresia ca e o rasnita buna-am vazuto la 1000 lei. Sunt foarte curios sa aud ceva in legatura cu ea
Gaggia Clasic + Pid _ Fiorenzato F5
Chiar 920lei.
Cutite plate de 49mm. i1 are 54mm in aceeasi categorie de pret. E de vazut si interiorul cum e facut, daca e ca i2 cu plastic, clar nu merita atatia bani.
Pe Coffeegeek cineva cerea o parere legata de Minimoka si a primit mai multe raspunsuri , cu link-uri spre diferite poze .
Raspunsul care urmeaza mi se pare relevant si vine sa întărească punctul de vedere exprimat mai sus de Lyvyoo .
Hi Eric,
The grinder in the first link is the i-steel I-1 as the i-mini I-1 has different case (the shop's description at the title is not correct). So assuming that the grinder for sale is the one shown in the picture and is the I1 type, I think is a very good choice, at a very good price, and I cannot see why the Eureka is a better grinder as it has smaller burrs of 50mm in comparison to 54mm of the ascaso.
I do not know the other Spaniard, Demoka  Minimoka, but again I would prefer the ascaso because of the larger burrs and the slightly more powerful motor.
Regarding the rpm, only the Eureka has a high rpm (1350). The other two, both have a low 700 rpm. In theory, low rpm cause less quality deterioration of the ground coffee due to the less heat that is generated during grinding. IMHO, not a matter of a great concern when grinders are used for small quantities of coffee as in home use.
Postarea asta am gasit-o si eu...dar nimic mai mult..
La banii astia probabil ca o marca consacrata este mai potrivita...
Intre timp, un an si ceva mai tarziu, pretul a coborat la 412 lei, la evomag, (432 la eMag) ceace in mod normal ar face-o deal-ul absolut, neexistand ceva similar chiar la pret dublu...
Avand in vedere politica magazinului de returnare a oricarui produs cumparat online in 14 zile (30 zile la eMag), nu vad de ce nu ar face cineva un test fara sa riste nimic... Confused
Cel mai rau lucru care se poate intampla e sa fie buna, si sa strice socotelile la multe nume sonore in gama 1000 lei Smile
Cineva nu fost atent. Aia la 432 e semijucarie. 0203 e 1174.
Ma rog, am gresit putin topicul. Il rog pe Liviu sa mute postarea.
Gaggia Color; Quamar T80e
Intr-adevar, este alta decat cea din titlul topicului.
Au aceleasi cutite plate de 49mm, reglaj cica micrometric, pana la proba contrarie... jucarie sa fie, daca zici dumneata...
Nu sunt interesat de electrice, ca as testa-o eu, am mai returnat si stiu ca functioneaza.
Pare acelasi lucru cu asta http://m.emag.ro/rasnita-de-cafea-delong...E0CDTBBBM/
Trebuie putin modificata pt espresso.
Am studiat si eu modelul asta in urma cu 2-3ani.
Chiar acelasi model nu este, sunt multe deosebiri, pozitia butonului de actionare, reglajul finetei macinaturii, butonul lateral este la una pe stanga, la una pe dreapta... cosul are alta aliniere cu hopper-ul.
Seamana atat cat seamana o rasnita cu alta... ca are cutite care se invart Smile
Multe rasnite folosesc aceleasi cutite si rezultatul e altul. Wink
Este interesant totusi ca timpurile ne permit testare gratuita si ne ferim de asta... Wink nu ne plac deceptiile, preferam sa traim inconjurati de like-uri... Smile
N-am mai apucat sa mai intru pe aici. Mi-am luat eu modelul asta de rasnita de vreo luna si ceva.
Se pricepe sa rasneasca pentru espresso.
Reglarea cred ca e intr-adevar micrometrica. Invarti de butonul ala de te doare mana.
Lelit PL41TEM / Minimoka GR 0203
Care din ele ? Smile
Cea din titlu Smile GR 203 (1174 la emag)
O rasnita interesanta...gasita din greselala..poate sunt doritori...cutite plane de 49mm si 700rpm 200W
http://www.emag.ro/rasnita-cafea-semipro...m_term=ad1
Daca nu am postat unde trebuie se poate sterge.
Bezzera MAGICA | Quamar M80E | La Marzocco Strada 14g | Motta knock box | Tamper Motta Competition | Pitcher Motta 35cl
Are topicul ei propriu, de cativa ani buni pare ca nu si-a dovedit valoarea...
Cutite plane de 49mm... poate fi mai rau de atat ? Confused Huh
Sunt cotate cam la paritate cu cele conice de 38mm care sunt in multe entry level.
Eu sunt multumit de ea dupa cateva luni de utilizare. N-am cu ce s-o compar, dar isi face treaba Smile
